Latest version of WinSCP keeps crashing
adrian@dotfusion.ro
Romania
Hi guys,
I am experiencing a lot of crashing issues ever since the last update.
I am using Windows 10 and my WinSCP instance and configuration has been pretty stable so far.
I have already tried uninstalling and reinstalling back again without any change in behavior.
Is there anybody else having similar issues? Can I install an older version maybe?
Thank you,
Adrian
Re: Latest version of WinSCP keeps crashing
adrian@dotfusion.ro
Romania
Thank you.
I have downloaded it and opened it.
I will use in the upcoming days. Do I need to send you anything back? Like a log?
Thank you,
Adrian
Alex2021
Resurrection
Hi!
I know this is old but I got the exact same issue for ages now with every WinSCP version on multiple PCs.
I noticed that this started to happen since I donated and entered my mail address in WinSCP - BUT: I did not donate enough for the auto update feature!
The point is: The software starts crashing randomly as soon as a new update is out.
seems like there is a relation.
Re: Resurrection
@Alex2021: Thanks for your report.
TVOTractor
WinSCP crashes on Windows 2019
Hi There,
I'm having a similar issue on an Evaluation copy of Windows 2019. When I start a transfer, the application crashes. I thought this might be related to the size of the file, and I tried to transfer a very small file. This worked. Larger files still cause it to crash.
Any suggestions would be most welcome.
John
Re: WinSCP crashes on Windows 2019
@TVOTractor: Thanks for your report.
