"Internal Server Error" delted local folders!
johnmsch
Atlanta
I have a script that has been running successfully for a couple years. Yesterday it got a "500 Internal Server Error" and deleted two folders on the local server that had hundreds of folders with tens of thousands of files. Fortunately, I was able to restore the folders from a backup. Below is the log from when this happened.
Is there a setting I'm missing? Is this a bug? The local folders shouldn't have been deleted just from an internal server error.
X:\FormularyDirectory\etc\DavClient>"C:\Program Files (x86)\WinSCP\WinSCP.com" /script=FormularyDownload.WinSCP.PROD.scp /timeout=120
batch           continue
reconnecttime   120
echo            on
option
echo            on
batch           continue
confirm         off
reconnecttime   120
failonnomatch   off
open https://xxxxxxx:***@files.xxxx.net/webdav -timeout=120
Connecting to host...
Authenticating...
Authenticated.
Starting the session...
Error changing directory to '/webdav'.
Session started.
Active session: [1] xxxxxxx:***@files.xxxx.net
synchronize local X:\FormularyDirectory\etc\DavClient\downloads\xxxx\webdav\Formulary /webdav/Formulary -delete -criteria=either
Comparing...
Local 'X:\FormularyDirectory\etc\DavClient\downloads\zzzzz\webdav\Formulary' <= Remote '/webdav/Formulary'
Error listing directory '/webdav/Formulary'.
(A)bort, (R)etry, (S)kip: Skip
Synchronizing...
'X:\FormularyDirectory\etc\DavClient\downloads\zzzzz\webdav\Formulary\FBS_1_0' deleted
'X:\FormularyDirectory\etc\DavClient\downloads\zzzzz\webdav\Formulary\FBS_3_0' deleted
johnmsch
Atlanta
Thanks for the quick reply @martin.
During syncs, I occasionally get a "Could not read response body: connection timed out" error, but the script will continue on to the next file, as I have it set to skip those. When they are skipped, it continues on to the next file. If I use the abort option, will WinSCP stop? Given that this process can sync hundreds, if not thousands of files per day, I really need it to continue on with this minor error. It does however make sense to stop with the internal error, as that one is fatal.
OK, it makes sense in this specific scenario. And there will be other scenarios, where "internal error" is recoverable. There's no easy solution.
Would you rather post a log file for the "Could not read response body: connection timed out" error? Maybe there's a way to improve robustness for that scenario.
johnmsch
Atlanta
Here are some snippets from a recent log file, where it gets an error, skips the file and continues on:
GA47607_20190616_20190616 |         321 KB |  239.3 KB/s | binary |  99%
Error transferring file '/webdav/Formulary/FBS_3_0/OPTUMCOM/FSL/GA47607_20190616_20190616'.
Could not read response body: An existing connection was forcibly closed by the remote host.
(A)bort, (R)etry, (S)kip, Ski(p) all: Skip
GA47623_20190616_20190616 |         323 KB |  222.5 KB/s | binary | 100%
SC30434_20190616_20190616 |         323 KB |   66.9 KB/s | binary |  99%
Error transferring file '/webdav/Formulary/FBS_3_0/OPTUMCOM/FSL/SC30434_20190616_20190616'.
SC30526_20190616_20190616 |         326 KB |   60.9 KB/s | binary | 100%
These are the two types of errors I sometimes see. WinSCP is doing exactly what I expect, and I see the dilemma on your side in how to handle the "500 Internal Error". IMO, the 500 is a fatal error and WinSCP should stop then and there.
Thank You
