Exclude Dir with Powershell
I have the built-in extension "KeepLocalUpToDate.ps1" working to sync my remote dir to my local, but I was wondering how to exclude a few dirs that I do not want sync'd. This is what I have now:
# @name &Keep Local Directory up to Date... # @command powershell.exe -ExecutionPolicy Bypass -File "%EXTENSION_PATH%" ^ # -sessionUrl "!S" -localPath "%LocalPath%" -remotePath "%RemotePath%" ^ # %Delete% %Beep% %ContinueOnError% -interval "%Interval%" -pause ^ # -sessionLogPath "%SessionLogPath%" # @description Periodically scans for changes in a remote directory and ^ # reflects them on a local directory # @version 5 # @homepage https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date # @require WinSCP 5.12 # @option - -run group "Directories" # @option RemotePath -run textbox "&Watch for changes in the remote directory:" "!/" # @option LocalPath -run textbox ^ # "... &and automatically reflect them on the local directory:" "!\" # @option - -config -run group "Options" # @option Delete -config -run checkbox "&Delete files" "" -delete # @option Beep -config -run checkbox "&Beep on change" "" -beep # @option ContinueOnError -config -run checkbox "Continue on &error" "" -continueOnError # @option Interval -config -run textbox "&Interval (in seconds):" "30" # @option - -config group "Logging" # @option SessionLogPath -config sessionlogfile # @optionspage ^ # https://winscp.net/eng/docs/library_example_keep_local_directory_up_to_date#options param ( # Use Generate Session URL function to obtain a value for -sessionUrl parameter. $sessionUrl = "*MY-SESSION-URL*", $localPath = "D:\Source", $remotePath = "/downloads", [Switch] $delete, [Switch] $beep, [Switch] $continueOnError, $sessionLogPath = $Null, $interval = 30, [Switch] $pause ) try { # Load WinSCP .NET assembly $assemblyPath = if ($env:WINSCP_PATH) { $env:WINSCP_PATH } else { $PSScriptRoot } Add-Type -Path (Join-Path $assemblyPath "WinSCPnet.dll") # Setup session options $sessionOptions = New-Object WinSCP.SessionOptions $sessionOptions.ParseUrl($sessionUrl) $session = New-Object WinSCP.Session # Optimization # (do not waste time enumerating files, if you do not need to scan for deleted files) if ($delete) { $localFiles = Get-ChildItem -Recurse -Path $localPath } try { $session.SessionLogPath = $sessionLogPath Write-Host "Connecting..." $session.Open($sessionOptions) while ($True) { Write-Host "Synchronizing changes..." $result = $session.SynchronizeDirectories( [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $delete) $changed = $False if (!$result.IsSuccess) { if ($continueOnError) { Write-Host "Error: $($result.Failures[0].Message)" $changed = $True } else { $result.Check() } } # Print updated files foreach ($download in $result.Downloads) { Write-Host "$($download.Destination) <= $($download.FileName)" $changed = $True } if ($delete) { # scan for removed local files (the $result does not include them) $localFiles2 = Get-ChildItem -Recurse -Path $localPath if ($localFiles) { $changes = Compare-Object -DifferenceObject $localFiles2 ` -ReferenceObject $localFiles $removedFiles = $changes | Where-Object -FilterScript { $_.SideIndicator -eq "<=" } | Select-Object -ExpandProperty InputObject # Print removed local files foreach ($removedFile in $removedFiles) { Write-Host "$removedFile deleted" $changed = $True } } $localFiles = $localFiles2 } if ($changed) { if ($beep) { [System.Console]::Beep() } } else { Write-Host "No change." } Write-Host "Waiting for $interval seconds, press Ctrl+C to abort..." $wait = [int]$interval # Wait for 1 second in a loop, to make the waiting breakable while ($wait -gt 0) { Start-Sleep -Seconds 1 $wait-- } Write-Host } } finally { Write-Host "Disconnecting..." # Disconnect, clean up $session.Dispose() } } catch { Write-Host "Error: $($_.Exception.Message)" } # Pause if -pause switch was used if ($pause) { Write-Host "Press any key to exit..." [System.Console]::ReadKey() | Out-Null } # Never exits cleanly exit 1
