How to build a continuous FTP monitor and transfer
some2lovewisp
Re: How to build a continuous FTP monitor and transfer
Anonymous wrote:
It seems to work for a minute or so, and then quits from a timeout error... Is there some way to keep the FTP connection alive?
It seems Session.FileTransferred never returns...
some2lovewisp
I take that back, it's the check() function that throws the error...
Error: Lost connection.
Timeout detected. (data connection)
Error listing directory '/mydirectory'.
