WinSCP dll (powershell) putfiles long path name
Marwa
I created a powershell script to transfer files from local path to remote path, when the file path is greater than 260 winscp throws exception and stops transfer, my question is can i ignore the error of long path name and continue transfer the rest of files? also i tried to get all the files less than 250 characters but it doesn't work.
here is my script, thanks
param (
    $localPath = "F:\Test1\*",
    $remotePath = "/Test1"
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "203.59.234.21"
        UserName = "ftpuser"
        Password = "eight*eight=64"
        SshHostKeyFingerprint = "ssh-rsa 1024 2i34SDb4+UdjGY8D20qJpbiTWP9Vly51ILjGN96/5bY="
    try
       #transferoptions
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
        # Connect
        $files=(Get-ChildItem -Path $localPath -Recurse | where {$_.fullname.Length -lt 250})
        foreach ($Fileinfo in $files) {
           $session.PutFiles($Fileinfo.FullName , $remoteFilePath)
               Write-Host ($Fileinfo.FullName)
    finally
        $session.Dispose()
catch
    Write-Host $_.Exception.Message
    exit 1
Re: WinSCP dll (powershell) putfiles long path name
WinSCP should support long paths. Make sure you have the latest version of WinSCP:
https://winscp.net/tracker/821
Though it can also be a server-side limitation.
Hard to tell without see an exact error message or even better a session log file (Session.SessionLogPath).
