Different tab name if login to a single site or using a site folder
Sopor
Sopor avatar
Sweden
I open several sites by selecting a folder and press Login. In version 5.15.1 the "Site folder" was showing the name of the sites, but in 5.15.2 it will now instead show the host name. So if i name my site to "mycoolsite" with IP address 123.123.123.123 and i login to this site only it will show "mycoolsite" in the tab, but if i instead select the site folder and press Login to open several sites it will now show the host name 123.123.123.123 in the tab.
So why will it use site name when i login on a single site and the host name when i login from a site folder? It make no sense.
Description: Here is a picture showing the difference between the versions!
