how to create an entire login(site) via command promt
Hi all, I'm trying to add a login to winscp via command prompt. But I'm unable to find an waay to do it? it is possible, or sites/user info can only be added in UI Login window?
I need to have it stored to avoid to have the user and password stored in my batch file (I'm building a schedule task to send files every day)
