Large (GT100GB) uploads to S3 fail
KernelPanic
Error: Part number must be an integer between 1 and 10000, inclusive Extra Details: ArgumentName: part Number, Argument Value: 10001,
Winscp should use a larger value for the multipart, or allow a configuration option to set this.
KernelPanic
The issue is the multipart chunk size...
This is defined in the libs3. (s3.c)
#define MULTIPART_CHUNK_SIZE (15 << 20) // multipart is 15M
Making this 30M would allow for 100GB transfers, 60M for 200GB transfers.
The upstream project (libs3) has updated this to:
#define MULTIPART_CHUNK_SIZE (768 << 20) // multipart is 768M
Can winscp please be rebased with the updated libs3?
https://winscp.net/tracker/1764
If you send me an email, I will send you back a development version of WinSCP for testing. Please include link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
