Error when trying to connect to a SFTP a specific country
hglzm
Hello Martin,
I am getting the following error when trying to connect to a SFTP file from Brazil. It is not a permissions issue because I have asked other colleagues to use my username and password and they are available to connect from other countries.
I don't believe this to be a network issue because I have tried it on different networks and always get the same error message.
I have attached a log file (with some personal information sanitized) for your review.
Could you please advise?
Thank you,
Humberto
  • winscp_connection.log (28.3 KB, Private file)
Description: File created using debug-2 option.
hglzm
I forgot to add, I have also tried using a different account for this FTP server and get the same message which is:
(EFatal) Server unexpectedly closed network connection. Cannot initialize SFTP protocol. Is the host running an SFTP server?
hglzm
Hello Martin,
Thank you for your response. Yes, I have tried using FileZilla and I am able to connect using both accounts from the same networks without any problems.
Let me know if you need any other details.
Regards,
Humberto
