Limited drive space. How to move WinSCP to D:?
Speedo
Denver
Using current free WinSCP. Single-user at home.
Many laptops now boot from a C: SSD that is space limited. Recent Win10 updates complain of limited drive space available.
How can WinSCP be re-located to a drive D: or other specifiable storage device while preserving configuration data?
Does the WinSCP.ini contain ALL of the configuration data? Is there ANY config data in the registry?
Can the temporary storage be re-defined for any directory on D:, or does it require a specific name or permissions?
In my case, I have a an .ini file in the default Program Files (x86) WinSCP directory on C:. Can I just copy all the files/folders in the directory to a directory on D:. Then re-define temp storage location, and create shortcut to WinSCP.exe in the new location?
Thank you. WinSCP is great.
Re: Limited drive space. How to move WinSCP to D:?
When you use INI file for configuration, it contains everything.
Yes - https://winscp.net/eng/docs/ui_pref_storage
No.
Yes. Though it's a strange setup. You generally do not have a write access to Program Files (x86). So you should not have an INI file there. Unless you run WinSCP with Admin privileges or you have allowed writing to Program Files (x86) (both is wrong).
Though a way easier is to move the WinSCP folder and create a symlink from the original location. Then you do not have to change any shortcut. And WinSCP installer will be able to correctly update your copy of WinSCP, when upgrading.
