WebDAV: PROPPATCH lastmodified instead of getlastmodified
dansoftware
dansoftware avatar
Orel, Russia
Hello.
WinSCP uses property getlastmodified with PROPPATCH method to modify mtime of a file on a WebDAV storage. It is incorrect. getlastmodified is read only and should be used with PROPFIND only. lastmodified property should be used with PROPPATCH instead: https://github.com/owncloud/core/issues/19737 Please, fix the problem.
dansoftware
dansoftware avatar
You are right. This is my post on ownCloud repository. Nor lastmodified nor getlastmodified does not work with ownCloud actually. It seems that there is a bug in ownCloud around PROPPATCH+lastmodified. It responses HTTP/1.1 200 OK but mtime of a file is not changed actually. I do not use any other WebDAV server. So I don't know how lastmodified property is well supported.
I do not know any WebDAV server that does support lastmodified either. On the contrary there is a server that does support getlastmodified. That's why WinSCP uses it.
Once there's any server that correctly supports lastmodified, I'm happy to change WinSCP behavior.
