Deprecated features: command-line parameter and saved sites
mpilot
Houston, TX, USA
From the other posts in this forum I am getting the impression that WinSCP's command-line interface is focused on scripting for automation and not for interactive users. Although WinSCP has a nice GUI with choices, I still prefer using the command-line for multi-file development projects, because it avoids the time to load the screen from large directories and I already know the names of the files I am after.
We use WinSCP as a replacement for Windows' command-line ftp and were surprised to see the "deprecated" and "saved sites" messages when we upgraded from 5.1.5 to 5.15.3. Setting up saved sites to be used as command-line parameters is the most convenient way to access specific machines and directories for interactive command-line users.
Opening session using command-line parameter in scripting is deprecated.
In scripting you should not rely on saved sites, use this command instead:
I can understand not using parameters and saved sites for scripting, since this impacts portability. But both features are invaluable for interactive use and I am concerned that "deprecated" means that one or both of them may be removed in future releases.
Would you please consider retaining our ability to specify a saved site on the command line interactively?
Re: Deprecated features: command-line parameter and saved sites
Are you aware of what that warning exactly means?
It says that you should not do
winscp site /command commands
But:
winscp /command "open site" commands
It does not limit you anyhow.
It just warns you that you are combining features that were never intended to be combined.
Also, we are definitely not intending to remove the ability to load stored sites in scripting (although we discourage it).
https://winscp.net/eng/docs/scripting#configuration
