Azure support
Re: Azure support
Azure WebJob runs basically in a full Windows environment. It can do almost anything you can do on Windows.
willv
Re: Azure support
So how do i define the PUT command when referencing the blob storage?
put test.blob.core.windows.net/data/test.zip /Test/
Re: Azure support
OK, it's misunderstanding. I didn't mean that WinSCP can do that.
I've meant that in Azure WebJob, you can do basically anything, including download from the blob. But you need to use a different tool for that. Once you manage to download the files, you can use WinSCP to upload the files to the "3rd party site".
willv
Re: Azure support
I tried sending a test file using a webjob and it failed. below is the log. any idea?
[code][08/28/2019 19:30:24 > 0d1e3e: SYS INFO] Status changed to Initializing
[08/28/2019 19:30:24 > 0d1e3e: SYS INFO] Status changed to Failed
[08/28/2019 19:30:24 > 0d1e3e: SYS ERR ] Failed to copy job files: System.IO.IOException: The process cannot access the file 'D:\home\site\wwwroot\App_Data\jobs\triggered\TestFtp\Azure WinSCP\WinSCP.exe' because it is being used by another process.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.File.InternalCopy(String sourceFileName, String destFileName, Boolean overwrite, Boolean checkHost)
at System.IO.File.Copy(String sourceFileName, String destFileName, Boolean overwrite)
at System.IO.Abstractions.FileWrapper.Copy(String sourceFileName, String destFileName, Boolean overwrite)
at Kudu.Core.Infrastructure.FileSystemHelpers.CopyDirectoryRecursive(String sourceDirPath, String destinationDirPath, Boolean overwrite) in C:\Kudu Files\Private\src\master\Kudu.Core\Infrastructure\FileSystemHelpers.cs:line 241
at Kudu.Core.Infrastructure.FileSystemHelpers.CopyDirectoryRecursive(String sourceDirPath, String destinationDirPath, Boolean overwrite) in C:\Kudu Files\Private\src\master\Kudu.Core\Infrastructure\FileSystemHelpers.cs:line 250
at Kudu.Core.Jobs.BaseJobRunner.<>c__DisplayClass49_0.<CacheJobBinaries>b__0() in C:\Kudu Files\Private\src\master\Kudu.Core\Jobs\BaseJobRunner.cs:line 183
at Kudu.Core.Infrastructure.OperationManager.<>c__DisplayClass2_0.<Attempt>b__0() in C:\Kudu Files\Private\src\master\Kudu.Core\Infrastructure\OperationManager.cs:line 16
at Kudu.Core.Infrastructure.OperationManager.Attempt[T](Func`1 action, Int32 retries, Int32 delayBeforeRetry, Func`2 shouldRetry) in C:\Kudu Files\Private\src\master\Kudu.Core\Infrastructure\OperationManager.cs:line 42
at Kudu.Core.Infrastructure.OperationManager.Attempt(Action action, Int32 retries, Int32 delayBeforeRetry) in C:\Kudu Files\Private\src\master\Kudu.Core\Infrastructure\OperationManager.cs:line 14
at Kudu.Core.Jobs.BaseJobRunner.CacheJobBinaries(JobBase job, IJobLogger logger) in C:\Kudu Files\Private\src\master\Kudu.Core\Jobs\BaseJobRunner.cs:line 179
[08/28/2019 19:30:24 > 0d1e3e: SYS ERR ] WebJob run failed due to: System.InvalidOperationException: Missing working directory
at Kudu.Core.Jobs.BaseJobRunner.InitializeJobInstance(JobBase job, IJobLogger logger) in C:\Kudu Files\Private\src\master\Kudu.Core\Jobs\BaseJobRunner.cs:line 232
at Kudu.Core.Jobs.TriggeredJobRunner.<>c__DisplayClass10_1.<StartJobRun>b__0(Object _) in C:\Kudu Files\Private\src\master\Kudu.Core\Jobs\TriggeredJobRunner.cs:line 77
