SshHostKeyFingerprint does not match
AxelG
here is my problem.
I have created a session in . NET (Visual Studio 2015).
My "SshHostKeyFingerprint" has never been accepted.
The String contains:
mySessionOptions.SshHostKeyFingerprint
= "ssh-ed25519 256 xirJmD/0DgUenJZ7msgH+jEsE+1J/QbYK7rQu0ZpFV8="
The answer is:
"Host key does not match configured key ""ssh-ed25519 256 xirJmD/0DgUenJZ7msgH+jEsE+1J/QbYK7rQu0ZpFV8=""!"
"Host key fingerprint is ssh-ed25519 256 xirJmD/0dgUenJZ7msgH+jEsE+1J/QbYK7rQu0ZpFV8=."
"Authentication failed."
What is wrong?
I have copied the string exactly- from the logfile of a gui-session.
Thanks a lot for helpful advises!
Re: SshHostKeyFingerprint does not match
Are you sure that this is your exact code?
The error message shows otherwise. It looks like you have too many quotes in the code (in red):
If it does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
AxelG
Yes, this is my code exactly:
.SshHostKeyFingerprint = "ssh-ed25519 256 xirJmD/0DgUenJZ7msgH+jEsE+1J/QbYK7rQu0ZpFV8="
Its exactly the copy of the generated VB.NET-Code from a GUI-Session.
In a Script it works fine with this:
/log=%LOG_PATH% /logsize=5*10M /ini=nul ^
/command ^
"open sftp://sftp-gwg:uVu2-aK8@app.gwg-reutlingen.de/ -hostkey=""ssh-ed25519 256 xirJmD/0dgUenJZ7msgH+jEsE+1J/QbYK7rQu0ZpFV8="""
I have copied my code/mylogfiles in several files, see as attachment.
Thanks for your Help!
Description: The logfile from the Script (that works!).
Description: The logfile from the VB.NET-Project.
Description: Extraction from VB.NET-Assembly-Code.
The line with "Fingerprint"is exactly the same, what a GUI-Session has shown.
You are have "D" in the code, while there's "d" in the actual fingeprint:
AxelG wrote:
The answer is:
