Connect Failure to Openssh_3.5p1 / Openssl 9.6.h
blacksun1102
Viet Nam
Hello !
Today I first tried to use the Winscp2.1 (verson 1 gives a putty out of memory error) - and tried to connect to my 2 Linux Servers - both using openssh3.5p1, one compiled with openssl9.6g (were it works wonderful) and the other with openssl9.6h (doesn't work)
The thing I'm really wondering about is, that I can connect to both using putty0.53b, pagent and psftp (the putty scp command line client) without having any problems..
Further I tried exchanging the sshd_config file - but I didn't change anything...
I 'll attach the logfile, maybe any of you can tell me what went wrong, or maybe anyone can tell me what to do, 'cause I don't find anything wrong as the connection seems to be enabled..
thx, markus
Logfile :
. WinSCP Version 2.1.0 (Build 119)
. Login time: Mittwoch, 15. Januar 2003 15:32:43
. Session name: max@193.170.29.193
. Host name: 193.170.29.193 (Port: 22)
. User name: max (Password: No, Key file: No)
. SSH protocol version: 2 only; Compression: No
. Agent forwarding: Yes; TIS/CryptoCard: No; KI: Yes
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Shell: default, EOL: 0
. Local directory: default, Remote directory: home, Update: No
. Clear aliases: Yes, Unset nat.vars: Yes
. Looking up host "193.170.29.193"
. Connecting to 193.170.29.193 port 22
. Server version: SSH-2.0-OpenSSH_3.5p1
. We claim version: SSH-2.0-PuTTY-Local: Jan 12 2003 19:45:16
. Host key fingerprint is:
. ssh-rsa 1024 7f:df:e1:ee:43:4a:0d:7a:c8:e8:27:78:0f:dd:17:9d
. Pageant is running. Requesting keys.
. Pageant has 0 SSH2 keys
. Keyboard-interactive authentication refused
. Sent password
. Access granted
. Opened channel for session
. Requesting OpenSSH-style agent forwarding
. Agent forwarding enabled
. Started a shell/command
. Doing startup conversation with host (shell).
> echo "WinSCP: this is end-of-file:0"
< Last login: Wed Jan 15 15:30:41 from oeh-mac1
. Server sent command exit status 0
* (ESshFatal) Error skipping startup message.
