The server is a debian
mysterio152
Hi all,
Should the speed be this low?
My transfer speed is only at most 50kbyte/sec. ordinary ftp connection gives me almost 300kbyte/sec. (they are not on the same LAN)
The server is a debian PII-350MHz 256meg memory latest OpenSSH
and my client pc is a 2.53GHz P4.
I've tested to use SSH1 only when connecting, but just as slow!?
Re: The server is a debian
That's not much.
Did you check CPU load of the server during the transfer?
Did you test any other client?
