Unable to download file -> Mask is invalid near
Grizzler
Hi.
I'm trying to download a file "Koala??<>>:::***|?.jpg".
It's always the same error message:
Mask is invalid near '>>:::***|?.jpg'.
With RemotePath.EscapeFileMask:
Mask is invalid near '>>:::[*][*][*]|[?].jpg'.
Is there a way to disable this masking stuff?
Re: Unable to download file -> Mask is invalid near
https://winscp.net/tracker/1781
Meanwhile, you can workaround it by escaping the < and > explicitly by doubling them:
See https://winscp.net/eng/docs/file_mask#size_time
Though note that the above is an invalid Windows filename anyway. It will get "escaped" to
