WinSCP.SessionRemoteException error
thijsemans
Hi all,
I am currently trying to create a FTP backup script to download files from an PLC system. However when I am trying to get an overview of the root this first thing I receive is an error like below:
FTP Download Error: WinSCP.SessionRemoteException: Error listing directory 'LIST DISK>D:\'.
It seems like the PLC is returning an root location back to the application that winscp cannot handle. Is there a way to work around this, like not using any feedback or so. Just forcely scan directories and files?
I now use the sessionoptions as below:
Protocol = Protocol.Ftp,
PortNumber = 21,
HostName = _ftpServer,
UserName = _ftpUser,
Password = _ftpPassword,
FtpMode = FtpMode.Active
I first used the synchronization mode, but after that was not working out I tried just to enumerate the directories and files but this was also not working. Strangely enough, the standard windows FTP command is working fine.
Does anyone have experience with this?
Re: WinSCP.SessionRemoteException error
WinSCP does not work well with non-Unix-like systems unfortunately:
https://winscp.net/tracker/49
There's hardly anything you can do about it.
But we can check anyway. Please attach a full session log file showing the problem (using the latest version of WinSCP).
