Copy filename (and/or path) from Synchronization checklist window
leonbloy
Currently the Synchronization checklist window lacks any way of copying to the clipboard the filename of each listed item.
I think that would be useful, when one wants to check (outside winscp, locally or remotely) about some file.
leonbloy wrote:
The description does not exactly fit the requested feature, but anyway it's something.
OK, but it fits your use case, doesn't it?
I have further improved the change to fit it even better:
https://winscp.net/tracker/1784
