Screwed up WinSCP somehow
W Lee
I was trying to use WinSCP's scripting to automate downloading - and in the script I modified one of the values to be a %DATE% %TIME% variable. Now, whenever I try to download, I get an error in the Authentican Banner: EFT Login - %DATE% %TIME% - Please enter valid credentials to continue.
I've uninstalled/reinstalled multiple times, tried clearing files, etc. Where is the hidden cache that this keeps referring to?
Re: Screwed up WinSCP somehow
W Lee
Uploaded log session and screen shot from WinSCP
  • winscp_upload.log (5.14 KB, Private file)
  • winscp_error.jpg (28.73 KB, Private file)
Description: Screen shot of WINSCP window
I do not see any %DATE% nor %TIME% in the log. It does not look like it's coming from WinSCP side. Did you contact your server administrator?
