Line We claim version: SSH-2.0-WinSCP_release_5.15.3 creates 500 Syntax error on FileZilla Server
X-CHECK2
P.O. Box 37, CH-8606 Greifensee
Starting WinSCP.exe (Version 5.15.3 (Build 9730) (OS 10.0.18362 - Windows 10 Enterprise)
. 2019-09-07 12:16:35.230 --------------------------------------------------------------------------
. 2019-09-07 12:16:35.231 WinSCP Version 5.15.3 (Build 9730) (OS 10.0.18362 - Windows 10 Enterprise)
. 2019-09-07 12:16:35.231 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2019-09-07 12:16:35.232 Log level: Normal
. 2019-09-07 12:16:35.232 Local account: DESKTOP-GR17LSI\Alfred Schaffer
. 2019-09-07 12:16:35.232 Working directory: C:\Program Files (x86)\WinSCP
. 2019-09-07 12:16:35.232 Process ID: 10140
. 2019-09-07 12:16:35.233 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2019-09-07 12:16:35.233 Time zone: Current: GMT+2, Standard: GMT+1 (Mitteleuropäische Zeit), DST: GMT+2 (Mitteleuropäische Sommerzeit), DST Start: 31.03.2019, DST End: 27.10.2019
. 2019-09-07 12:16:35.234 Login time: Samstag, 7. September 2019 12:16:35
. 2019-09-07 12:16:35.234 --------------------------------------------------------------------------
. 2019-09-07 12:16:35.234 Session name: FTP-Test_SFTP@127.0.0.1 (Site)
. 2019-09-07 12:16:35.234 Host name: 127.0.0.1 (Port: 22)
. 2019-09-07 12:16:35.234 User name: FTP-Gast (Password: Yes, Key file: No, Passphrase: No)
. 2019-09-07 12:16:35.234 Tunnel: No
. 2019-09-07 12:16:35.234 Transfer Protocol: SFTP (SCP)
. 2019-09-07 12:16:35.234 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec
. 2019-09-07 12:16:35.234 Disable Nagle: No
. 2019-09-07 12:16:35.234 Proxy: None
. 2019-09-07 12:16:35.234 Send buffer: 262144
. 2019-09-07 12:16:35.234 SSH protocol version: 2; Compression: No
. 2019-09-07 12:16:35.234 Bypass authentication: No
. 2019-09-07 12:16:35.234 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes
. 2019-09-07 12:16:35.234 GSSAPI: Forwarding: No; Libs: gssapi32,sspi,custom; Custom:
. 2019-09-07 12:16:35.234 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No
. 2019-09-07 12:16:35.234 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1
. 2019-09-07 12:16:35.234 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto
. 2019-09-07 12:16:35.234 Simple channel: Yes
. 2019-09-07 12:16:35.234 Return code variable: Autodetect; Lookup user groups: Auto
. 2019-09-07 12:16:35.234 Shell: default
. 2019-09-07 12:16:35.234 EOL: LF, UTF: Auto
. 2019-09-07 12:16:35.234 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No
. 2019-09-07 12:16:35.234 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No
. 2019-09-07 12:16:35.234 SFTP Bugs: Auto,Auto
. 2019-09-07 12:16:35.234 SFTP Server: default
. 2019-09-07 12:16:35.234 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2019-09-07 12:16:35.235 Cache directory changes: Yes, Permanent: Yes
. 2019-09-07 12:16:35.235 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2019-09-07 12:16:35.235 DST mode: Unix
. 2019-09-07 12:16:35.235 --------------------------------------------------------------------------
. 2019-09-07 12:16:35.292 Looking up host "127.0.0.1" for SSH connection
. 2019-09-07 12:16:35.292 Connecting to 127.0.0.1 port 22
. 2019-09-07 12:16:35.294 We claim version: SSH-2.0-WinSCP_release_5.15.3
. 2019-09-07 12:16:50.404 Waiting for data timed out, asking user what to do.
. 2019-09-07 12:16:50.404 Asking user:
. 2019-09-07 12:16:50.404 **Host is not communicating for 15 seconds.
. 2019-09-07 12:16:50.404 Wait for another 15 seconds?** ()
. 2019-09-07 12:16:55.345 Attempt to close connection due to fatal exception:
* 2019-09-07 12:16:55.345 **Terminated by user.**
. 2019-09-07 12:16:55.345 Closing connection.
. 2019-09-07 12:16:55.345 Sending special code: 12
* 2019-09-07 12:16:55.390 (EFatal) **Terminated by user.**
Checking FileZilla Server.Log, it says "500 Syntax error, command unrecognized"
for command "SSH-2.0-WinSCP_release_5.15.3"
(000001) 07.09.2019 12:16:35 - (not logged in) (127.0.0.1)> Connected on port 22, sending welcome message...
(000001) 07.09.2019 12:16:35 - (not logged in) (127.0.0.1)> 220-FileZilla Server 0.9.60 beta
(000001) 07.09.2019 12:16:35 - (not logged in) (127.0.0.1)> 220-written by Tim Kosse (Tim.Kosse@gmx.de)
(000001) 07.09.2019 12:16:35 - (not logged in) (127.0.0.1)> 220 Please visit https://filezilla-project.org/
(000001) 07.09.2019 12:16:35 - (not logged in) (127.0.0.1)> SSH-2.0-WinSCP_release_5.15.3
(000001) 07.09.2019 12:16:35 - (not logged in) (127.0.0.1)> 500 Syntax error, command unrecognized.
(000001) 07.09.2019 12:16:55 - (not logged in) (127.0.0.1)> disconnected.
Line "We claim version: SSH-2.0-WinSCP_release_5.15.3" is new and only seen under Windows 10
Question:
Is there a possibility to suppress line "We claim version: SSH-2.0-WinSCP_release_5.15.3"
or do I need to change to FileZilla Client under Windows 10?
Re: Line We claim version: SSH-2.0-WinSCP_release_5.15.3 creates 500 Syntax error on FileZilla Server
(Free) FileZilla server is FTP server only.
You have to use FTP to connect to it. Not SFTP. (Mis)Configuring an FTP server to run on an SSH/SFTP port 22, does not make it an SFTP server. It's still FTP.
