Cannot transfer files with german umlaut
cmos12345
I know there have been many topics here about problems with german umlauts. But I didn't find any solution for my issue so far.
We're trying to transfer a file with the german umlaut 'ä' in the filename using the .NET library of WinSCP via SFTP.
When opening the WinSCP UI, the filename is also not displayed correctly. There will be a '?' instead of 'ä' in the filename.
We tested with every of the UTF flags in WinSCP without success, but we were able to transfer the file using Filezilla, so the server seems to support UTF.
cmos12345
Re: Cannot transfer files with german umlaut
We managed to transfer the files via winSCP client now (there was a problem with the server)
We use a pretty old version of winSCP at this particular client.
How do we set UTF flag in our code, when we do not have session.AddRawSetting available?
Helvetica
Switzerland
Just for information - using Umlaute or French accents in file names can cause a lot of errors in your log. I accidently uploaded some files using the word Babelon_Traité_(number).jpg and txt and I found literally hundreds of error reports in my server log and google's log.
Perhaps it may be easier to use ae for ä, ue for ü, oe for ö etc. if your files are accessible to the public.
cmos12345
Sadly, we are not able to influence the filenames in any way.
Is there any way to set the UTF flag using "session.AddRawConfiguration()"?
We tried with
session.AddRawConfiguration("Utf", "0");
but this did not work.
It's SessionOptions.AddRawSettings.
See https://winscp.net/eng/docs/library_sessionoptions_addrawsettings
sessionOptions.AddRawSettings("Utf", "1");
WinSCP GUI can generate a code template for you:
https://winscp.net/eng/docs/ui_generateurl#code
