Network Error: Connection Refused
BWHITE
I have 26 devices at separate locations. The are all created from the same image. 25 of the 26 are able to connect and transfer data to the ftp server. The other is failing with the following: . Connecting to 208.88.0.63 port 22
Failed to connect to 208.88.0.63: Network error: Connection timed out
Knocking FTP port.
. FTP port did not open.
Any thoughts on what might be blocking this from the network side? It has connected once over the past two months, So I do not believe it is the setup on either server but in the network between them. I need something to give to the network team.
Thank you
