- PkChris
- 4
- Canada
Windows Store Version Has Tiny Taskbar Icon
The latest update to the Windows Store version made the taskbar icon really tiny.
Site Admin -
- 43,173
- Prague, Czechia
Re: Windows Store Version Has Tiny Taskbar Icon
What is your monitor settings? Do you have multiple monitors? What Display Scale do you have set in Windows Settings?
- PkChris
- 4
- Canada
Ah right, sorry for the lack of detail.
It's happening on my work laptop which is a MacBook dual booting Windows hooked up to 2 1080p monitors (appears tiny on all 3 screens) and on my home PC hooked up to a single 1440p monitor.
Happens on all resolution scalings. Start menu tile has normal sized icon. It became tiny after the most recent update.
Site Admin -
OK, I can maybe reproduce it now. I get the small icon, when I pin the app to the task bar. When I run the app, the icon is normal. When I close it, the pinned small icon re-appears. Is that the behavior that you experience?
For me it's always tiny if the app is opened, closed, pinned or not. Here's a video of what I'm seeing.
https://video.vidyard.com/watch/fqx7PkhcAWH6RgnH5jdy5w
Site Admin -
- 43,173
- Prague, Czechia
Issue 1793 – Start menu and Task bar icons are too small when installed from Microsoft Store
@martin: The build you sent me fixed it! Thanks for looking into this!
Site Admin -
Thanks for your feedback!
- Guest
Greetings,
same problem here. May you please send me the fix for it? I would be glad if you could update the fix version in Microsoft Store too.
Best regards,
Chris
Best regards,
Chris
- Guest
Hi Martin,
did I made something wrong that I bought the software from MS Store? Using the free version was everything ok. Small feedback would be appreciated.
best regards,
Chris
best regards,
Chris
Site Admin -
- 43,173
- Prague, Czechia
@Guest: I'm happy to send it. But I have no way to reach you.
Can you send me an email? Please include a link back to this topic in your email. Also note in this topic that you have sent the email. Thanks.
We will of course update the Store version, once we actually release the fix. Probably in few weeks.
