Authentication Failed.
anisfarim
Malaysia
I already have a script to open a winscp with scripting for task scheduler. But when I run it I get an error for "Connection has been unexpectedly closed. Server sent command exit status 0. Authentication log (see session log for detail):... Authentication Failed. " why this happen?
Please help me...
Re: Authentication Failed.
