Trying to File transfer to Mainframe
pasupuletitrivkram
Bangalroe
Hi Team,
I am trying to do file transfer to mainframe using winscp.com .The following commands are used
Winscp>open <mainframe_server_address:990>
Winscp> Userid: Usr-id given
Winscp>Password: password given
connecting to <mainfame_server_address:990>....
TLS Connection Established and waiting for messagge
Starting session..
Session Stared
Active Session..
winscp>put c:\temp\test.txt XXXXX.YYYYY.ZZZZ.DG191004
file got transfered to successully but the dataset on mainframe created with prefix of user-id
USERID.XXXXX.YYYYY.ZZZZ.DG191004
But I wanted to send the file as .XXXXX.YYYYY.ZZZZ.DG191004 to mainframe.
Could you please help asap?
amkMj5o
I believe you want to cd up before your put command. Some mainframe systems put you in a "directory," for lack of a better term, that is your user id upon login.
So try cd .. before put. You may also need to cd XXXXX and then cd YYYYY. In that case, you would be putting file ZZZZ.DG191004
