Bad CPU type in executetable
canhnm
Apple have just realease MacOS Catalina update, after the process now Wine returns error once it execute:
- Commonand: Wine
- Return: Bad CPU type in executable
Checking wine type:
file /usr/local/Cellar/wine/4.0.2/bin/wine
/usr/local/Cellar/wine/4.0.2/bin/wine: Mach-O executable i386
Anyone here faced it before?
Re: Bad CPU type in executetable
Afaik, Catalina does not support 32-bit applications anymore. WinSCP is 32-bit application. So that probably the reason.
canhnm
Thank you, I have just also noticed about that. Any suggest solution?
