Issues with filemask
                I'm having troubles getting the filemask to work properly.  I hope you can see my error.
Using ListDirectory("/Build/TESTING"), I see this file/folder structure:
/Build/TESTING/.
/Build/TESTING/..
/Build/TESTING/.DS_Store
/Build/TESTING/A.rtf
/Build/TESTING/Alpha
/Build/TESTING/B.rtf
/Build/TESTING/Beta
/Build/TESTING/Omega
A.rtf and B.rtf are files
Alpha, Beta and Omega are folders
I'm trying to download B.rtf only. Here are examples of what I have tried.
options.FileMask = "B.rtf|*/"; //nothing copied
options.FileMask = "B.rtf | */"; //nothing copied
options.FileMask = "B.rtf; | */"; //nothing copied
options.FileMask = "B.rtf;|*/"; //nothing copied
options.FileMask = "B.rtf"; // B.rtf plus subfolders downloaded
options.FileMask = "|*/"; // nothing copied
options.FileMask = "| */"; // nothing copied
options.FileMask = "* | */"; // nothing copied
options.FileMask = "*.rtf | */"; // nothing copied
options.FileMask = ""; // all files and folders are copied
What is the correct filemask to only download B.rtf?
Thanks in advance.
/Build/TESTING/.
/Build/TESTING/..
/Build/TESTING/Beta
Thanks in advance.
