Specify record length while sftp to mainframe in .NET code
Ankitakha
Hi, I am transferring file to mainframe server using WinSCP SFTP .NET code. I have to specify record length while transferring file. At my end record length is 2214 but when I am transferring file it is creating file with 100 length. I tried all transfer modes ASCII, Automatic and Binary. When I was using FTP protocol with ASCII, it used to create file with same record length of 2214. But with SFTP I am facing this issue.
Re: specify record lenth while sftp to mainframe in .net code
There's no "record length" in SFTP. If your mainframe SFTP server supports that, it must be some kind of a hack or a proprietary feature. If you provide us any documentation about that, we can help you with setting it up in WinSCP. Are you able to specify the record length in any other SFTP client?
Ankitakha
Hi, Thanks for replying. While using FTP protocol, I didn't specify any record length. At my end length of record is 2214 and while doing session.put() record length is same. But when I am using SFTP protocol, my line is breaking at 100 length and going to next line. Not sure if I have to set any attribute?
Hi Tried using this but getting error.
Cannot overwrite remote file "FineName".$$
Press 'Delete' to delete the file and create new one instead of overwriting it.$$
And also, even after error, it is creating file on server but with no data.
Below is the code that I used.
    Protocol = Protocol.Sftp,
    HostName = "ServeName",
    UserName = "Userid",
    SshHostKeyFingerprint = "------------",
    SshPrivateKeyPath = @"----------------",
sessionOptions.AddRawSettings("FSProtocol", "2");
sessionOptions.AddRawSettings("CacheDirectories", "0");
sessionOptions.AddRawSettings("CacheDirectoryChanges", "0");
    session.Open(sessionOptions);
    TransferOptions transferOptions = new TransferOptions
    { TransferMode = TransferMode.Automatic, };
    session.ListDirectory("/+lrecl=35");
    session.ListDirectory("/+RECFM=FB");
    session.PutFiles(sourcepath, cpedFilename, false, transferOptions).Check();
If I am removing
then it is creating file with data but of record length 128.
Let me know if I am doing anything wrong.
Ankitakha
Hi I found the solution and its working fine for me.
I used
session.ListDirectory("/+recfm=fb,lrecl=2214,blksize=0,replace/");
to create file with record length of 2214 in mainframe. I am not getting "Cannot overwrite remote file "FineName".$$" error when I used /replace in session.ListDirectory().
Andres Gomez
Hi, I have this problem,
Error listing directory '/+lrecl=35'.
The file path does not exist or is invalid.
// Setup session options
    HostName = "10.0.0.7",
    PortNumber = 2222,
    UserName = "user",
    Password = "password",
    SshHostKeyFingerprint = "ssh-rsa 2048 JEdoyPd09IwNgLHT6mnRJunJwO6GihiHhrTgq0TXrks"
    // Connect
    // Upload files
    session.PutFiles(@"C:\Temp\LOTE1808.035", "/public/test2/", false, transferOptions).Check();
