Locking down Server session
anser316
London
I can set File Protocol and Hostname for session by using the ini file.
Is there anyway the login can be locked down so they can not edit the site/session details?
Setting the ini file to read-only permission does stop changes to be saved, but a user can still edit the site config and login without saving.
Re: Locking down Server session
What is your goal?
Do you want to prevent the users from connecting anywhere else?
anser316 wrote:
Yes please, we only want them to log on to one File Protocol and hostname, and be restricted to not connect to anything else.
No you cannot prevent WinSCP from connecting somewhere.
anser316
London
We do want them to connect somewhere, but no where else, just one connection.
Can the resource hacker tool do this?
Well, that's the same.
