Winscp 4.2.1. Waiting for data timed out, asking user what to do,Host is not communicating for 15sec
mohit
USA
We are getting timeout error in one legacy system,here is application logic. We see an error "Waiting for data timed out, asking user what to do, Asking user Host is not communicating for 15 seconds." at step#3.
Please provide solution for this specific version of winscp.
1. Create a new session through command script and download files from FTP server to local, after that close the FTP connection.
"C:\WinSCP\winscp.com" /timeout=30 /script=\"C:\test\FTPScript.txt\" /ini=\"C:\test\FTPSettings.ini\" /log=\"C:\test\ftplog.txt\" > abclog.txt
2. Add entry in DB.
3. Create a new session through command script and delete the files from FTP server which has been processed in above steps.
"C:\WinSCP\winscp.com" /timeout=30 /script=\"C:\test\FTPDelScript.txt\" /ini=\"C:\test\FTPSettings.ini\" /log=\"C:\test\ftplog.txt\" > abclog.txt
. 2019-10-29 23:12:13.413 Looking up host "ftp000.ABC.com"
. 2019-10-29 23:12:13.413 Connecting to <IP addess> port 22
. 2019-10-29 23:12:28.414 Waiting for data timed out, asking user what to do.
. 2019-10-29 23:12:28.414 Asking user:
. 2019-10-29 23:12:28.414 Host is not communicating for 15 seconds.
. 2019-10-29 23:12:28.414 Wait for another 15 seconds? ()
. 2019-10-29 23:12:28.414 Attempt to close connection due to fatal exception:
* 2019-10-29 23:12:28.414 Terminated by user.
. 2019-10-29 23:12:28.414 Closing connection.
. 2019-10-29 23:12:28.414 Sending special code: 12
mohit1
I got the solution.. added timeout in Ini file.
Re: Winscp 4.2.1. Waiting for data timed out, asking user what to do,Host is not communicating for 15sec
You urgently need to upgrade as well.
