Application error using WinSCP on Windows Server in Azure
momiyama
Japan
I've created a Windows application which uses WinSCP 5.13.3 (DLL) to download files from a secure FTP site. This has been working for several weeks until today when I received the error message,
'WinSCP process terminated with exit code -1073741819 (C0000005). There was no output. Response log file C:\Users\xxx\AppData\Local\Temp\wscp1044.01EA0A2F.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.'
I Googled the error and just found the recommendation that I should be using the latest version of WinSCP, which I do. I'm able to run the WinCP exe without any problems. Any helpful information beyond "be sure you have the latest version" would be appreciated.
prachi06
Mumbai
WinSCP Issue
I am also getting the same issue. Is there any resolution for this? I am pulling the files using Azure Timer Trigger functions. I am getting below error
Timeout waiting for WinSCP to respond - WinSCP has not responded in time. There was no output. Response log file D:\local\Temp\wscp226C.03C48178.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
Re: Application error using WinSCP on Windows Server in Azure
momiyama wrote:
I've created a Windows application which uses WinSCP 5.13.3 (DLL) to download files from a secure FTP site. ...
How exactly do you run that application?
Re: WinSCP Issue
I'll try to reproduce the problem with Azure Functions.
Is this also a new problem? Was it working before?
prachi06
Mumbai
Re: WinSCP Issue
No it was not working before
prachi06
WinSCP Issue
Issue is resolved at my end. Previously I have created the Timer Trigger function so when that trigger was automatically executed, it was using Local User Account which has permission issue. So to overcome this permission issue, I have created one HTTP trigger function so when that trigger is executed from browser it is using IIS user account and it has all permission so it executed successfully.
prachi06
Mumbai
WinScp Issue in Timer Trigger
I have follow steps from below link for Timer Trigger azure function
https://winscp.net/eng/docs/guide_microsoft_azure_function_sftp
I have assign the executable path as specified in above url. But when connection is opening(session.Open(sessionOptions);) I am getting the error as below
Please can you explain what other setting you have done to avoid this error.
prachi06
Mumbai
Please find attached function file. The code which I have attached is for HTTP Trigger function. When I am calling using that trigger also I am getting same issue.
Re: WinScp Issue in Timer Trigger
I have asked for a whole project.
Anyway, did you try using the exact code from the sample? No async/Task stuff. The AuthorizationLevel.Anonymous can also have an effect on this.
