How to upload files to FTP by latest date?
guard100
I try to create upload multiple files which create which apply on same date but it only uploaded on latest files instead of all files created on same date.
try
# Load WinSCP .NET assembly
Add-Type -Path "WinSCPnet.dll"
Move-Item -Path \\unc\d\xxx\xxx\*.csv -Destination \\unc\d\xxx\xxx\uploaded -Force
# Setup session options
Protocol = [WinSCP.Protocol]::ftp
HostName = "xxxxx"
UserName = "xxxxx"
Password = "xxxxx"
try
# Connect
$localPath = "\\unc\d\xxx\xxx\uploaded"
$remotePath = "/Inbound"
# Select the most recent file.
# The !$_.PsIsContainer test excludes subdirectories.
# With PowerShell 3.0, you can replace this with -File switch of Get-ChildItem.
$latest =
Get-ChildItem -Path $localPath |
Where-Object {!$_.PsIsContainer} |
Sort-Object LastWriteTime -Descending |
Select-Object -First 1
# Any file at all?
if ($latest -eq $Null)
Write-Host "No file found"
# Upload the selected file
$sourcePath = Join-Path $localPath $latest.Name
$session.PutFiles(
[WinSCP.RemotePath]::EscapeFileMask($sourcePath),
[WinSCP.RemotePath]::Combine($remotePath, "*")).Check()
finally
# Disconnect, clean up
$session.Dispose()
catch
exit 0
Re: How to upload files to FTP by latest date?
What some date?
Do you want to use PowerShell? Or simple WinSCP scripting?
