Synchronize files via sftp, error 127 (in gui over command line)
dziurexoo
Poland
I try to automatic synchronize files from Windows to Linux via sftp.
I wrote simple winscp script:
# Connect to SFTP server using a password
winscp.com /ini=nul /script=test1.txt
open sftp://user:password@192.168.168.111 -hostkey="ssh-ed25519 256 xxxxxxxxxxxxxx=:
synchronize remote /root/pr C:\Program Files\Microsoft SQL Server\MSSQL15.MSSQLSERVER\MSSQL\Backup
# Exit WinSCP
and i tried with:
option batch abort
synchronize remote C:\Program Files\Microsoft SQL Server\MSSQL15.MSSQLSERVER\MSSQL\Backup  /root/pr
# Exit WinSCP
and i used GUI to generate code:
open sftp://user:password@192.168.168.111/ -hostkey="ssh-ed25519 256 xxxxxxxxxxxxxxxxxxx="
lcd "C:\Program Files\Microsoft SQL Server\MSSQL15.MSSQLSERVER\MSSQL\Backup"
cd /root/pr
put *
and I have scp.txt with
 C:\Program Files (x86)\WinSCP\WinSCP.exe /log=C:\Program Files (x86)\WinSCP\WinSCP.log /ini=nul /script=C:\Program Files (x86)\WinSCP\scp.txt
And it doesn't work, maybe have i some mistake in script? In a backup folder i have files like example.bak
