Batch file to get file using stored session
darlington.cam
Utah
I'm attempting to create a batch file to get a file without using plain text username and password. I was hoping to use saved sessions with the hashed password but can't figure out the correct syntax
The following currently works, but how do I use the stored .ini and eliminate my password?
@echo off
"C:\Program Files (x86)\WinSCP\WinSCP.com" /command "open sftp://user:pass@siteid/"
"get -lastest /media/*.jpg C:\media\"
"exit"
I've tried adding /ini="C:\media\WinSCP.ini" where I've stored the config, but I don't know how to apply it correctly and change how it opens
