How to lock parent directory for a distant folder when creating connexion
Marc80
Amiens
Dear community,
I would like to share a folder from my computer Ubuntu 18.04 to others computers which are all on Windows.
That's why I installed ssh-serveur on mine, and WinSCP on the other one.
I create a connexion to my folder when the software is launched. It works because you arrived in my folder, and then you need a password each time you enter ...
Nevertheless when you are in the folder shared, you can enter to the parent directory and navigate into all my files, and I don't want !!
So, do you know how ocnfig a connexion to lock the parent directory of the folder chosen in the connexion ? Does it work from windows pc or mine (owner of the server ssh) ?
thanks you for your answear !
