Help with scheduling uploads with wildcards in the file names
xtraozon
Sweden
Hello.
I am new to WinSCP but i hope it will be the tool i need for a task i have.
I need a script to automatically connect to a ftp server each night and upload CSV files to two folders.
The files will be named something like Fakturor_20191129.csv and betalningar_20191129.csv.
The files starting with fakturor must be uploaded to a folder called reminder, and betalningar to a folder called payment.
I have written the following script and created a task in task scheduler, but it is not working so i am obviously doing something wrong.
I would also like the script to download all the files in another folder on the server, delete them, and then download them to E:\Root\Apps\Winbas\foobar\foobar.
Any help would be appreciated.
open ftp://user:password5@ftp.server.com/
cd /reminder
put E:\Root\Apps\Winbas\foobar\Fakturor\fakturor*.csv
cd /payment
put E:\Root\Apps\Winbas\Wbserv\foobar\Fakturor\betalningar*.csv
# Kör skriptet med ett kommando som:
# "C:\Program Files (x86)\WinSCP\WinSCP.exe" /log="C:\ftp\WinSCP.log" /ini=nul /script="C:\ftp\sync.txt"
Re: Help with scheduling uploads with wildcards in the file names
Does the first upload work?
The second upload never happens as you exit the script.
Remove the first exit (and the second open).
If this does not help, please attach a full session log file showing the problem (using the latest version of WinSCP).
