i cant see files
Nixion
i cant see files
Hi, I just downloaded the WinSCP to check out the sync function but there is no file on remote location.
the problem I have is this, on the target IP address, I can't seem to see the files in folder trends, the file in question is a "something.SKV" file.
more info
I can see "something.SKV" files on local
I can see "something.SKV" files on remote using Filezilla
I try to attach a log file.
Re: i cant see files
And can you see those files using any other client?
Nixion
I tried a few other programs to see if there was another one I could use and well it was a sad experience.
program that could see the files are:
FileZilla
programs that could not see the files are:
WinSCP
CoffeeCup Free FTP
SmartFTP Client
GoodSync
FTPbox
CoreFTP
tried some more weird ones but as I could not even get them to work I won't list them here.
but as an update, I did get it to work and I can now see the files but I am not sure why I did not change anything other than shut down the pc for the night and try again the next day.
