Syncronizing with problematic webdav connection
Snakeright
Italy
Hi, i need to synchronize my local folder from a webdav server that is slow and instable.
I need that the syncronizing restart when the connection go down. How can i resolve my problem? thanks
Re: Syncronizing with problematic webdav connection
