Prevent users from disabling logging and other unauthorised config changes
I've installed WinSCP 5.15.2 in a multiuser environment and have enabled XML logging. The WinSCP.ini file is read only so any changes they make to the Preferences are not saved.
The problem is for their active session they are able to disable logging (and make other config changes) it's just these changes are not preserved when the close WinSCP.
Is there a way to disable sections of the configuration menu so they cannot make changes at all please?
Many thanks
Herbert
Many thanks
Herbert
