Error with command keep local directory up to date
erickooij
Rotterdam, The Netherlands
Installed version 5.15.9 and when I run the command keep local directory up to date I get
following error message:
Error: Could not load file or assembly 'file:///C:\Program Files\WinSCP\WinSCPne
t.dll' or one of its dependencies. This assembly is built by a runtime newer tha
n the currently loaded runtime and cannot be loaded.
Press any key to exit...
erickooij
Fixed
Hi Martin,
Thanks for the reply, it fixed the problem.
Must run Windows 7 32 bit on this machine to keep ancient software in the air.
Kind regards,
Eric Kooij
