Fill in 'User Name' and 'Password' automatically, always the same, for all entries?
Bart
I'm using WinSCP 5.15 on Windows Server 2016, I've imported a bunch of Sites from Putty and I now want to fill in the username and password without obviously copy-pasting it a hundred times over. I didn't find this on the FAQ right away!
Is there any easy and simple way to do this? Thank you!
Bart
Bart
Great! So if I put this in a .bat file and I execute that line in the same folder where the WinSCP.ini is stored, this will work? Are there admin rights needed?
In a folder where winscp.exe is (or just use a full path to winscp.exe). Admin rights are not needed.
