Timeout detected. (control connection)
alvintc
UK
I've now finished everything I need... just now need to automate the pulling down of files/ folders.
I'm still testing using command prompt until the script is perfect, but on large files I'm receiving "timeout detected. (control connection)"... any suggestions?
My batch file is:
"C:\Program Files (x86)\WinSCP\WinSCP.com" /log="I:\SeedboxAuto\WinSCP.log" /ini=nul /script="I:\SeedboxAuto\WINSCPFULL.txt"
if %ERRORLEVEL% neq 0 goto error
:error
echo Error!
exit /b 1
The WINSCPFULL script is:
# Connect
open ftp://MASKED -rawsettings ProxyPort=0
# Download TV Shows newer than 2 minutes then delete
cd "/media/TV"
get -delete -filemask=<2N * "I:\TV-I\"
# Download Films newer than 2 Minutes then delete
cd /media/Films
get -delete -filemask=<2N * "E:\Films-E\"
# Disconnect
close
# Exit WinSCP
Re: Timeout detected. (control connection)
Can you download those files anyhow? Using WinSCP GUI? Using any other FTP client? If you can, please post a log file for that too.
