Can I reverse a "Synchronize" operation?
Jim605
Florida
Newby, here. Apologies if this has been covered.
I tried to set synchronization for a subfolder and actually synchronized the parent folder by mistake. I do not see any way to "unSynchronize" the parent folder and it may be a problem soon. Any help for me?
It occurred to me that this operation is merely a one-time function and that I might just delete the contents of the parent directory from the storage drive, but I fear making the problem worse if I do not confirm that with an experienced user. If I'm wrong, then the program will continue to replace the files I do not want synchronized.
Re: Can I reverse a "Synchronize" operation?
There is not way WinSCP would reverse the operation for you.
You have to do it manually.
And it's one time operation. WinSCP will not synchronize again on its own.
