Connecting to Sharepoint online
fitze50
Ireland
Hi Team,
I am unable to connect to sharepoint online from WinSCP.
The errors in the logs i get are :
. 2020-01-28 09:55:34.213 [hdr] X-MSDAVEXT_Error: 917656; Access+denied.+Before+opening+files+in+this+location%2c+you+must+first+browse+to+the+web+site+and+select+the+option+to+login+automatically.
. 2020-01-28 09:55:34.213 Header Name: [x-msdavext_error], Value: [917656; Access+denied.+Before+opening+files+in+this+location%2c+you+must+first+browse+to+the+web+site+and+select+the+option+to+login+automatically.]
I can attach logs if needed.
Alan.
Drit
I have same issue. Would like to connect with WebDAV method to sharepoint online (e.g. https://company.sharepoint.com/sites/sitename/libraryname). WinSCP return 403 Forbidden and after further analyzing it seems because of X-MSDAVEXT_Error.
Have tried the mentioned koskile link, but does not work. On connect with spo it ask for login, but when entering correct auth data it returns error "Current site is not a tenant administration site" or when not in domain "You can't get there from here".
This is not only issue of WinSCP, as a lot of programs seem to have this issue (f.e. cyberduck, total commander, filezilla, etc).
But there is proof it can work, as when map network drivein explorer with this url it does work and also the program "Allway Sync" is able to connect succesfully.
Drit
Yes it does, but it uses windows internal (crappy) webdav, url sometimes changes to \\company.sharepoint.com\DavWWWRoot\sites\sitename\libraryname
Allway sync does use it's own webdav method.
That's not WebDAV, not even URL.
