How to upload a file with a specific keyword in a name for SFTP using WinSCP?
I currently have a working script that uploads files to a remote SFTP directory. The problem I am facing is that there will be 3 files and they must be loaded in sequence at different intervals. I’ve already thought about using the Windows Task Scheduler to monitor the download frequency, but there is another problem. I determined that the files differ in name based on one keyword. Is there a way to change my code to search for files in a directory by a specific name? For example, he searches the directory for a file named "client" in his name. Based on this keyword / name, it then downloads this particular file. See the current working scenario:
# Load WinSCP .NET assembly Add-Type -Path "WinSCPnet.dll" # Setup session options $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Sftp HostName = "server" UserName = "username" Password = "password" SshHostKeyFingerprint = "key" } $session = New-Object WinSCP.Session try { # Connect $session.Open($sessionOptions) # Upload files $transferOptions = New-Object WinSCP.TransferOptions $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary $transferResult = $session.PutFiles("E:\CMBPAID", "/NESAMSCARIMED", $False, $transferOptions) # Throw on any error $transferResult.Check() # Print results foreach ($transfer in $transferResult.Transfers) { Write-Host "Upload of $($transfer.FileName) succeeded" } } finally { # Disconnect, clean up $session.Dispose() }
