Using configured transfer settings different from factory defaults. Unknown switch 'transfert'.
RLO
hi team,
when trying to dowlod multiple file from a remote sftp server on a scipt file i get this error.
here is my log :
E:\UVAREC\temp>E:\winscp577\winscp sftpvel/downloads /hostkey="*" /command "get -delete -transfert=binary order-*.zip \\mynas\interfaces\vel\paniers\" "EXIT"
Opening session using command-line parameter in scripting is deprecated. Use 'open' command instead.
Searching for host...
Connecting to host...
Authenticating...
Using username "myusername".
Authenticating with public key "imported-openssh-key".
Authenticated.
Starting the session...
Session started.
Active session: [1] sftpvel
E:\UVAREC\temp>if 1 NEQ 0 goto FIN_ANORMALE
here is my script :
%winScpDir%\winscp %sftpServer% /hostkey="*" /command "get -delete -transfert=binary %filetoreceive% %nasToReceive%\" "EXIT"
if %errorlevel% NEQ 0 goto FIN_ANORMALE
