Cannot locate COM executable
WilliamO
TN
I downloaded WinSCP – the paid version. I cannot seem to locate the .com executable and cannot run from the command line. I am looking to automate folder creation on a local machine and push to a Synology NAS.
Re: Cannot locate COM executable
By the "paid version", do you mean the Microsoft Store version?
While the Store versions comes with winscp.com, it is not easily available due to limitations of the platform: UWP console app with no icon, just execution alias.
You can use an absolute path, but it changes with every update:
C:\Program Files\WindowsApps\MartinPikryl.WinSCP_5.15.9.0_x86__tvv458r3h9r5m\WinSCP.com
You better download the portable package and use that.
marcosfrm
Any news on this? It would be nice use winscp.com from the Store, which is always up to date.
marcosfrm
Thanks. I ended up using in my CMD script:
start /wait winscp.exe /console /command "stuff 1" "stuff 2"
This way I can type the password (do not want it saved anywhere).
Let's hope Microsoft provides an API or whatever to make winscp.com work in the Store version.
WinSCP is great. Keep up the good work!
