Error connexion : Connecting to FTP error
steph07
I have a problem scripting.
this is the script :
# Specify directories
$localPath = "C:\Temp\script"
$remotePath =  "/test"
    # Load WinSCP .NET assembly
Add-Type -Path "C:\Program Files (x86)\WinSCP\WinSCPnet.dll"
try
    # Setup session options
        Protocol = [WinSCP.Protocol]::ftp
        HostName = "eportal-scheduled.services.xxxx.com"
        UserName = "eportal-ftp@anonyme.fr"
        Password = "xxxxxxxx*B"
    try
        # Connect
        Write-Host "Connecting to FTP..."
        # Download files
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
        Write-Host "Synchronizing changes..."
        $transferResult =
            $session.SynchronizeDirectories(
                  [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $false. $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Downloads)
            Write-Host "Download of $($transfer.FileName) succeeded"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
I have the result :
Error: Exception calling "Open" with "1" argument(s): "Connection failed.
Connection failed.
Sorry, cleartext sessions are not accepted on this server.
Please reconnect using SSL/TLS security mechanisms."
Can you help
Best Regards
Stephane
Re: Error connexion : Connecting to FTP error
To enable SSL/TLS, set SessionOptions.FtpSecure:
https://winscp.net/eng/docs/library_sessionoptions#ftpsecure
        FtpSecure = [WinSCP.FtpSecure]::Explicit
You might also need to set SessionOptions.TlsHostCertificateFingerprint.
steph07
Thank you Martin, it works now.
But sometimes, i have this error :
Error: Exception calling "Check" with "0" argument(s): "Error transferring file '/.ftpquota'.
Copying files from remote side failed.
Prohibited file name: .ftpquota"
I search to google this error "Prohibited file name: .ftpquota" but i didn't find anything.
Stéphane
That's not WinSCP message. It must come from your server.
If you cannot upload that file, you need to exclude it from the synchronization.
