SynchronizeDirectories Path Error
Rob_C
Australia (yes it does exist)
Hi folks.
Hoping someone can point me in the right direction:
Running SynchronizeDirectories in a .net app and for the life of me, I can't get past this error:
"Error listing directory \u0027/C:/Users/REMOVED/data/UAT/SOMETHING\\*.*\u0027.\r\nError retrieving file list for \"/C:/Users/REMOVED/data/UAT/SOMETHING\\*.*\".\r\nSystem Error. Code: 123.\r\nThe filename, directory name, or volume label syntax is incorrect"
The thing is, I am copying the remote path directly from the GUI in WinSCP.
I have tried just about any combination of characters. User has permission - obviously can verify with the GUI.
Code (snippet) is:
sessionOptions = new SessionOptions
   Protocol = Protocol.Sftp,
   HostName = Config.host,// "example.com",
   UserName = Config.username, // "user",
   Password = Config.password, // "mypassword",
   SshHostKeyFingerprint = Config.sslcert //= "ssh-rsa 2048 xxxxxxxxxxx...="
      // Will continuously report progress of synchronization
      session.FileTransferred += FileTransferred;
      // Connect
      session.Open(sessionOptions);
      // Synchronize files
      SynchronizationResult synchronizationResult;
      synchronizationResult =
      session.SynchronizeDirectories(
      SynchronizationMode.Remote, Config.remotepath,
      Config.localpath,
      false,
      false, SynchronizationCriteria.Time);
      // Throw on any error
      synchronizationResult.Check();
basically straight from the sample code.
Any suggestions greatly appreciated.
Cheers,
Rob
Re: SynchronizeDirectories Path Error
First, you have the arguments (named?) wrong. It's localPath, remotePath, not the other way around.
Then, your Config.remotepath (which actually seem to contain a local path) probably contains that \u0027. I'm not sure where/how did you get that error message. \u0027 is a single quote. But were it a single quote, it would probably be printed as an actual single quote. So maybe the Config.remotepath actually contains that literal sequence "\u0027".
This does not seem to be a WinSCP question, but generic programming issue. If you believe otherwise, please attach a full session log file showing the problem (using the latest version of WinSCP).
